Date/Time: Sun, 22 Dec 2024 14:13:00 +0000
how to enable toolbar quotes showing date, time, open, high, low, close?
View Count: 749
[2015-08-18 18:08:10] |
User767336 - Posts: 39 |
Hi ... downloaded Sierra update this morning, and now new format does not have the toolbar showing digital readout of open, high, low, close, etc. for any given bar when the pointer is positioned on it. Could not seem to find answer in the help menu. Thanks
[2015-08-18 18:31:48] |
Refer to this page here: New Control Bar to replace ToolBar and Status Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
