Date/Time: Fri, 25 Sep 2026 02:52:33 +0000
Heiken-Ashi
View Count: 2001
| [2015-08-18 14:53:33] |
| User21113 - Posts: 62 |
Line tool does not copy correctly to Heiken-Ashi chart. Chart 1: Candle chart. Draw a trend line with the line tool. Chart 2: Heiken-Ashi chart. The line tool is copied from chart 1. Notice the line tool is incorrectly copied to the Heiken-Ashi chart number 2. This does not occur with straight lines or rectangle tool. Those tools line up correctly. Also, the Heiken-Ashi data on chart 2 does match the data on the candle chart number 1. See image. |
| [2015-08-18 14:58:08] |
The Heiken-Ashi chart is a tick chart. When the chart is switched to a minute chart the line tool is applied correctly. |
| [2015-08-18 19:16:35] |
Also, the Heiken-Ashi data on chart 2 does match the data on the candle chart number 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-18 19:20:12
| [2015-08-18 19:17:57] |
Notice the line tool is incorrectly copied to the Heiken-Ashi chart number 2. Refer to this page for an understanding about this: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-18 19:21:12
