Date/Time: Sun, 22 Dec 2024 14:59:04 +0000
C drive full but E drive has space
View Count: 1676
[2015-08-17 22:43:17] |
User40526 - Posts: 166 |
how do I redirect data to my second hard drive my C drive is 60 gig and is almost full - I am getting alerts and today SC stopped updating data because the disk was full I have dumped all cache and eliminated a couple of programs (this computer is used solely for trading - no email or anything else) - I do disk cleanup every day and defragment weekly my E drive has 124 gig free but I don't know how to redirect the SC data to the E drive Thanks |
[2015-08-17 22:54:38] |
This can be done through Global Settings >> General Settings >> Data Files Folder. You will need to move the files from the existing Data Files Folder to the new one. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-17 23:28:38] |
Hmmm, sorry to be so obtuse, but it keeps defaulting back to the C drive. I have copied the directive (? not sure that's what you call it) and only changed the drive to E, but it seems to default back to the C drive. My entry in the Data Files Folder: is E:SierraChart\Data\ |
[2015-08-18 01:18:11] |
Follow these complete detailed instructions we have put together: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#ChangingDataFilesFolder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-18 05:57:44] |
User742717 Mike - Posts: 86 |
Sounds like your storing all the symbol tick data, Look under C:\SierraChart\Data and delete the .scid files of symbols which you don't use. On each chart you can set a limit of days to download, I suggest you manage that. |
[2015-08-18 11:17:27] |
Thanks, I made the changes suggested on data and the data files folder now has "E:\Sierra Chart\DATA\". I have unchecked the Always Use Data Folder Within Main Folder But now the charts aren't updating, so I repeated the above for the Chart Image Folder "E:\Sierra Chart\Images\" thinking that needed to be done, too, but still no updating of the charts. I can see the price changes on the values scale and the DOM, but the charts are frozen. |
[2015-08-18 11:46:14] |
Restart Sierra Chart. If you still have a chart updating problem, refer to help topic 3: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-20 18:36:25] |
This has been a struggle for me. Most recently my "file to open on startup" wasn't populating and I found an answer on the support board and got those files copied to the E drive. However, I still cannot get the "trade activity log" to populate any more than the current days trades. No history will populate, even the previous day. I copied more files like all the Tranact folder but no success. I now have more disk space devoted to the Sierra Chart folder on E drive than I have on the C drive, so it seems the necessary information would be there to populate my trading history. What am I missing? thanks |
[2015-08-21 09:30:17] |
This might possibly be due to a corrupt Trade Activity Log file. Update Sierra Chart to the latest prerelease using Help >> Download Prerelease. If the file is corrupt that will now automatically be detected and new file will be started. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
