Date/Time: Sun, 22 Dec 2024 14:40:36 +0000
SC transfer
View Count: 841
[2015-08-17 18:22:47] |
Dennis B. - Posts: 272 |
In your help topic you say transfer files from the "Data Files Folder" in old pc to the new one. Do you mean the "Data" folder. Can't find "Data Files Folder" |
[2015-08-17 21:02:09] |
The Data folder is considered the Data Files Folder . The specific location of that folder can be determined through Global Settings >> General Settings >> Data Files Folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-17 21:03:26
[2015-08-18 13:00:34] |
Referring to step # 5 in your transfer instructions. Do I have to copy/move all those files ? I do not use your trading platform at all. Trying to keep this as easy as possible. thx
[2015-08-18 17:49:50] |
None of the files in step 5 need to be copied. They are only necessary if you want everything to be exactly the same in the new installation of Sierra Chart.
