Date/Time: Sun, 22 Dec 2024 14:42:43 +0000
Working with Spreadsheets - pasting into range
View Count: 944
[2015-08-17 16:56:16] |
rhovega - Posts: 279 |
Can't paste a formula into a range. Following instructions here: http://www.sierrachart.com/index.php?page=doc/doc_Spreadsheets.html (" Copy the content by selecting Spreadsheet >> Copy. Select the range of cells that you want to be filled in with the contents of the originally selected cell or cells, and paste the contents by selecting Spreadsheet >> Paste. If you are copying a formula, then the cell references will be automatically adjusted unless they are absolute references.") Following those instructions can only paste in the top cell of the range, not the full range. Please help. |
[2015-08-18 19:13:46] |
Are you running New Spreadsheets or Old Spreadsheets? We will update the documentation to make sure it is clear and correct for New Spreadsheets. What you want to do is supported with New Spreadsheets if you use Spreadsheet >> Copy Formula and Spreadsheet >> Paste. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-19 13:14:09] |
How to determine if running New Spreadsheets or Old Spreadsheets?
[2015-08-19 17:07:11] |
This is indicated at the top of the Window >> Show/Hide Message Log in newer versions of Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-19 17:09:50
[2015-08-20 03:50:11] |
The documentation has been updated.
