Date/Time: Sun, 22 Dec 2024 11:00:45 +0000
Triangle, Trapezoid
View Count: 946
[2015-08-17 14:16:47] |
User788947 - Posts: 7 |
Recognizing the time constraints of the programmers, I would like to renew a request I see in previous posts over the years for a triangle tool on the charts. It is a very popular tool in the charting world for describing Gartley patterns, batwing patterns, and the like. I have a screengrab from another charting program to demonstrate but don't see a way to attach it. I expect a trapezoid tool would be helpful for many as well, for describing diamond patterns and the like. For me, though, the triangle is the tool that I use regularly, so that is my request. :-) |
[2015-08-17 15:29:12] |
I see someone else renewed (sort of) the same request just an hour before. It's popular, I tell you!
[2015-08-18 11:41:12] |
We will see about a triangle drawing tool.
[2015-08-18 11:45:04] |
Marek F - Posts: 244 |
+1
