Date/Time: Mon, 23 Dec 2024 01:19:28 +0000
Trade DOM graph
View Count: 844
[2015-08-14 18:52:48]
SgtJ - Posts: 154
There doesn't appear to be a way to adjust the colors of the trade DOM graph (trade, draw dom graph on chart). It can be adjusted on a chart though. Default colors are backwards, but being able to adjust would be ideal.
[2015-08-16 14:32:02]
SgtJ - Posts: 154
Can you also enable the "recent traded" column to work during a replay?
[2015-08-18 09:56:02]
Regarding the first post, we will work on this.
Regarding the second post, this is not possible to be supported during a replay. Or is very hard. So this capability will not be added.
[2015-09-09 15:43:12]
SgtJ - Posts: 154
re the "recent traded" column, can you allow the user to reverse color levels based on a user threshold.... "reverse color recent trade column if > N" ty
