Date/Time: Sun, 22 Dec 2024 10:06:25 +0000
[User Discussion] - ACSIL - sc.AddACSChartShortcutMenuItem - related question
View Count: 786
[2015-08-13 16:04:11] |
ejtrader - Posts: 688 |
SC Team - At present have been using few menu items using the above function and they work properly as intended. There is a need to change the Text of the SAME menu item if possible(on certain conditions). Is there such option available at present? If not would it be possible to add one? Something like - sc.UpdateACSChartShortcutMenuItem() For example - I would have the default menu item: - display Text Once pressed - I would like to have the menu item to be changed to "clear text". At present I am using the menu item as "display Text - Toggle" to mimic the same but would be nice if I can change the text dynamically. thanks Date Time Of Last Edit: 2015-08-13 16:33:26
