Date/Time: Sun, 22 Dec 2024 09:53:56 +0000
Scroll Bar
View Count: 1282
[2015-08-13 15:10:25] |
User69931 - Posts: 1 |
I have 2 charts up from Chartbook 1. I detached one chart so there is one chart on each of my 2 screens. On the chart i detached the scroll bar at the bottom is greyed out and i dont see a full page of data. On the other screen i see a full page of data. Can you help? Jamie |
[2015-08-13 18:13:15] |
Refer to this section here about this: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
