Date/Time: Sun, 22 Dec 2024 09:55:24 +0000
Windows 10- Sierra frosen
View Count: 971
[2015-08-13 11:05:23]
User966853 - Posts: 1
Hi
I have win10 (past from win 7) and from yesterday I have problem with Sierra that freezes.
Before - no problem.
I have blocked also my antivirus, Windows defender, firewall, but Sierra is KO.
Reinstalling Sierra with new pre vers.1284 doesn´t work.
Also I have new java Ver.8 update 51. (I don´t know if it cause by java?)
Do You have any info about this problems?
Can You help me?
Thanks lot
[2015-08-13 16:11:44]
User98649 - Posts: 14
I had a similar freeze when I first installed Win 10. I set the Windows 7 compatibility mode for SierraChart.exe (right click and then select properties) and haven't seen any issues since then. hth.
[2015-08-13 18:37:39]
Also refer to help topic 30:
http://www.sierrachart.com/index.php?page=doc/helpdetails30.html
