Date/Time: Sun, 22 Dec 2024 10:12:34 +0000
Numbers Bar Calculated Values - Bar Duration Display
View Count: 1004
[2015-08-13 07:53:29]
User787778 - Posts: 142
Please provide an option as to what format this time is shown. For example only show minutes - not hours or seconds
The current status takes up alot of space and reduces the number of bars that are visable on a screen.
[2015-08-13 08:54:31]
This is not entirely possible because of how the table is designed. The table is designed to show single numbers only per cell. So it is either going to be seconds, minutes, or hours.
We do not see a reasonable solution to this and we will not try to offer one. We recommend using the Bar Duration study instead.
