Date/Time: Sat, 23 Nov 2024 01:03:12 +0000
IQFEED - Tenfore data
View Count: 1841
[2013-06-12 09:55:57] |
User95208 - Posts: 26 |
Has there been a change in the forex symbols please? I used to get forex symbols ending with .ABBA on SC. Example: eurusd.abba. This is Tenfore's best of bid and ask average. I do not get this anymore on SC anymore starting 7 June; instead, I had to use symbols without an extension, example: eurusd. The problem is the forex symbols with .abba had a long intraday history (1 minute history for more than 4 years on my data base). The forex symbols, without an extension, have just 3-4 months of data. Interestingly, the forex symbols feed with .abba extension does not come only on SC. I still get them in Amibroker and Ninja Trader! BTW, I am out of SATA empty space to plug in an SSD on my xw8600 workstation. I am looking out for a PCIe v 2.0 with an SSD backmount to switch to the SSD. Until then, I will have to use the SATA II HDD only. Please advise. |
[2013-06-12 10:12:16] |
This is because you are no longer using IQ Feed from Sierra Chart. You are using the Sierra Chart real-time Forex data feed instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-12 10:19:26] |
Blimey, Thanks for bringing it to my attention. I do not know what happened to the IQFeed connecting settings. I will investigate and fix. |
