Date/Time: Sun, 22 Dec 2024 11:28:49 +0000
Get number of Letters/Blocks per price of TPO Profile Chart in other study
View Count: 939
[2015-08-12 15:09:57] |
wat - Posts: 67 |
Is it possible to retrieve number of letters/blocks shown in TPO Profile Chart for other study? Or is its source code available somewhere that can be used to do so? Thank you. |
[2015-08-13 04:22:00] |
This is called the Total TPO Count. This can be viewed in the Chart Values window. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#TextInformation This data is also outputted to a Spreadsheet Sheet when using the Spreadsheet Study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-13 04:23:15
[2015-08-13 09:57:20] |
wat - Posts: 67 |
Is it also possible to retrieve TPO count per price? Thank you. |
[2015-08-13 10:37:25] |
The TPO count per price level can be displayed at each price level. There is an Input setting with the TPO Profile Chart study to display that information. However, it cannot be programmatically accessed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-17 15:00:34] |
wat - Posts: 67 |
Is it planned to make it accessible? Is the TPO study code available to be edited to make it so? Thank you. |
[2015-08-17 16:57:23] |
There are no plans for either of these.
