Date/Time: Sun, 22 Dec 2024 10:33:08 +0000
potential issue - Trade Activity Log - Period Stats - Daily
View Count: 967
[2015-08-12 02:35:27]
ejtrader - Posts: 688
SC Team - I have defined Daily Stats Reset Time as - 17:00:00 hours.
Looking at the Trade -> Trade Activity Log -> Period Stats for Daily --- It appears like it takes the trades taken after 17:00:00(before 00:00:00) as well into the daily stats. (it doesn't matter whether Fill-to-Fill is picked or Flat-to-Flat is picked.)
Based on my own tests - It appears like - you are taking 00:00:00 hours for the Daily Period Stats rather than Daily Stats Reset Time.
Is it by design or an oversight?
Technically the trades taken after 17:00:00 should be made part of the following day. Interestingly the study - "Trading: Profit/Loss Text" - is accurate from calculations point of view.
Would you please review?
thanks
Date Time Of Last Edit: 2015-08-12 02:44:55
[2015-08-12 03:51:21]
We will check on this.
[2015-08-13 03:52:14]
Al SC Developer - Posts: 434
In our testing, it appears that only the Daily Date can be wrong in the stats tab. The numbers are correct and appear the same as the study values like you mention. We will address the wrong date value.
[2015-08-13 04:46:27]
SC Team. Agreed. The Stats calculations are correct except few trades being categorized under a different Date.
Have been trying to build own trade statistics and when tried to validate my own calculations with built-in calculations, noticed this issue and reported.
thanks
