Date/Time: Sun, 22 Dec 2024 15:02:18 +0000
Cumulative Delta Bars - Value label not updating
View Count: 1077
[2015-08-11 19:01:18] |
davidbrooke - Posts: 55 |
The value label on Cumulative Delta Bars isn't updating as the data changes. It will update after a new candle is generated. Please refer to cdb-vlabel-1.png. The left most arrow is pointing to the close value which updates as expected but the right most arrow pointing to the value label doesn't update as the close value does. The photo shows the differences. I normally use the chart in a smaller window which the value label becomes very important. Please refer to cdb-vlabel-2.png. I can't get just the close value to be shown so I have to rely on the value label. Thanks |
cdb-vlabel-1.png / V - Attached On 2015-08-11 19:01:03 UTC - Size: 194.89 KB - 358 views cdb-vlabel-2.png / V - Attached On 2015-08-11 19:01:07 UTC - Size: 20.34 KB - 371 views |
[2015-08-11 19:03:08] |
I'm using SC version 1282.
[2016-04-15 16:21:33] |
kinghat - Posts: 120 |
on a similar question to this, how do you show the current value label? i see the open, high, low and close but not current price.
SierraChart_2016-04-15_11-21-10.png / V - Attached On 2016-04-15 16:21:27 UTC - Size: 39.53 KB - 310 views |
[2016-04-15 17:19:11] |
You need to enable the Value Label for the "Close" Subgraph: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#NameValueLabels The current Value Label is the "Close". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-15 17:19:24
[2016-04-15 18:08:01] |
thanks!
