Date/Time: Fri, 30 Oct 2026 09:54:19 +0000
Chart header vs 1282
View Count: 1204
[2015-08-10 20:51:01]
Crtfyd - Posts: 310
Downloaded vs 1282 over weekend.
My Chart Header no longer shows.
I changed nothing after download.
Is there a new check mark to show it?
[2015-08-10 21:56:10]
Based upon what you are describing in this post and another post about a missing study, it sounds as though there has been a problem with the reading of your Chartbook file which has resulted in a corruption.
We can test your Chartbook to see what the problem is because this should not have happened. It can be privately attached here.
the setting you are asking about is:
Chart >> Chart Settings >> Advanced Settings 2 >> Region Data Lines
