Date/Time: Sun, 22 Dec 2024 09:25:06 +0000
Custom Study sending emails not working - Account Support Ticket
View Count: 927
[2015-08-10 18:02:06]
Sebastian_M - Posts: 70
Hey Support,
I have created a custom study, and it gives me an alarm, but no email.
Can you help please?
Regards Sebastian
imageSierra_Image2.jpg / V - Attached On 2015-08-10 17:59:11 UTC - Size: 71.92 KB - 317 views
imageSierra_Image3.jpg / V - Attached On 2015-08-10 18:00:01 UTC - Size: 75.11 KB - 313 views
imageSierra_Image5.jpg / V - Attached On 2015-08-10 18:00:26 UTC - Size: 67.08 KB - 331 views
[2015-08-10 18:19:39]
What is the domain of the email address you are using?
[2015-08-10 18:20:39]
I am using 2, yahoo.com & gmail.com
[2015-08-10 18:22:40]
We had to block email messages to Yahoo.com to avoid mail delivery problems. You cannot use that domain.
[2015-08-10 18:33:12]
Working now, thank you.
Regards Sebastian
[2015-08-10 18:40:32]
P.S
Is there a sc. alert on bar close?
Regards Sebastian
[2015-08-10 19:02:30]
Refer to the documentation about this here:
https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetBarHasClosedStatus
[2015-08-11 15:03:21]
Hi Support, thank you for your reply.
I have attched 2 images.
Using the sc.GetBarHasClosedStatus() on the webpage and the studys collection, could you take a look at the images and notify me if they are in the correct place please? I did not get compilation errors.
Thank you in advance.
Sebastian
Date Time Of Last Edit: 2015-08-11 15:03:40
imageSierra_Image6.jpg / V - Attached On 2015-08-11 15:02:46 UTC - Size: 177.01 KB - 317 views
imageSierra_Image7.jpg / V - Attached On 2015-08-11 15:02:58 UTC - Size: 166.82 KB - 335 views
[2015-08-11 17:27:27]
sc.GetBarHasClosedStatus() must never be located within sc.SetDefaults. It will not work there.
[2015-08-11 17:30:50]
OK, thanks, where should it be? can you screenshot the location?
Regards S.
[2015-08-11 17:59:32]
This is for you to determine. Normally it will be located right after the sc.SetDefaults code block.
[2015-08-11 18:57:08]
Thanks support.
A good learning curve.
imageSierra_Image8.jpg / V - Attached On 2015-08-11 18:57:00 UTC - Size: 179.88 KB - 315 views
