Date/Time: Sat, 23 Nov 2024 01:29:04 +0000
CW ordering
View Count: 1652
[2013-06-12 06:41:06] |
TastyRisk - Posts: 119 |
Hi, I often have to manually rename my charts "001 contact name" "002 con..." and so on, so that I can easily find them in the Chart Window menu. It really takes up too much time. Please could you add the option to "sort by chart ID number" instead of just defaulting to alphabetical sort ? Date Time Of Last Edit: 2013-06-12 06:42:33
[2013-06-13 04:06:51] |
We will see what we can do.
