Date/Time: Sun, 22 Dec 2024 09:08:36 +0000
SC Data feed
View Count: 826
[2015-08-10 17:28:54] |
Neo - Posts: 198 |
I've just added the SC data feed. With the service for US equities(NYSE, NASDAQ, AMEX, OTCBB), will i receive data/ volume from all the trades that took place at the NBBO? Even if those trades came from other exchanges.
[2015-08-10 17:48:37] |
This we are not sure about. We need to find out about this.
[2015-08-10 18:47:03] |
We are not sure we fully understand the answer, but this is the answer we got: It's just NBBO. We don't send the BBO by sub-exchange.
[2015-08-10 19:15:41] |
Neo - Posts: 198 |
I think it means all the Data should be there.
