Date/Time: Sun, 22 Dec 2024 09:18:47 +0000
Cannot delete custom study files or generate custom study code
View Count: 872
[2015-08-10 14:12:12]
wat - Posts: 67
After update to SierraChart version 1282 I cannot remove custom study files, it throws error:
Error deleting wat24_volume_0.0.1.cpp file: " Windows error code 2: Systém nemůže nalézt uvedený soubor." | 2015-08-10 16:09:32 *
"Systém nemůže nalézt uvedený soubor" is "System cannot find selected file". The file exists and can be deleted manualy though.
Also when I am trying to generate new customy study it opens empty file, it generated stub before. I guess those issues might be connected.
Running on Windows 10.
[2015-08-10 17:30:26]
We are looking into these problems.
[2015-08-11 17:45:40]
This will be solved in the next release coming out this evening.
