Date/Time: Sun, 22 Dec 2024 09:14:41 +0000
Sierra Data feed question
View Count: 827
[2015-08-10 12:37:50] |
bookert4 - Posts: 56 |
Hello Support, I am currently working off the CTS4 platform for the next month, do I need to shut off my Sierra data feed ? |
[2015-08-10 17:12:29] |
Only if you do not want to use the Sierra Chart Exchange Data Feed. If you decide to cancel it, it will remain active until the end of August.
[2015-08-10 18:31:15] |
Support, Does the CTS4 HAVE DATA IN WHICH TO WORK FROM UNTIL I GET BACK TO AMERITRADE ? TRYING TO AVOID USING TWO SOURCES OF DATA IF I DO NOT NEED TO. |
[2015-08-10 18:36:24] |
Yes it does.
