Date/Time: Mon, 23 Dec 2024 15:57:37 +0000
Sorting capability on New Spreadsheets
View Count: 1336
[2015-08-10 06:58:28]
Marmany - Posts: 307
I note that "Old Spreadsheets will no longer be supported in new versions of Sierra Chart effective sometime in December 2015."
I currently use Old Spreadsheets on one copy of SC in order to use the Sort Function.
Please advise if you plan to add Sorting Capability to New Spreadsheets by December.
Many thanks.
[2015-08-10 18:31:25]
We will have to see about this.
We could add a very basic sort capability possibly.
In any case, it is not something we would get to soon so we just recommend that you continue to use the version that exists at that time and continue to use Old Spreadsheets.
Date Time Of Last Edit: 2015-08-10 18:32:55
[2015-10-09 11:00:37]
I note that sort capability has been added for new spreadsheets in v1306. Many thanks for this addition.
When sorting I normally do so on 2 columns (e.g. time of day plus one other). However the new capability only allows one column to be sorted.
Would it be possible for you to extend the capability to a second column?
[2015-10-09 17:41:50]
Are you referring to the number of columns to be used as a sort key?
[2015-10-09 18:41:01]
Yes that is correct. Old spreadsheets actually allow sorting using 3 columns as keys.
I only have a need to sort using 2 columns as sort keys.
Apologies for not making this clear in post #3.
I really hope you will be able to add the additional capability.
[2015-10-09 19:26:16]
OK only one column obviously is supported now. We will consider this later on but we cannot commit more time to it now.
