Date/Time: Sun, 22 Dec 2024 09:18:08 +0000
Compact Tool Values Window
View Count: 2074
[2015-08-08 17:32:22]
User21113 - Posts: 62
Within the Compact Tool Values Window,
Is it possible to only display the Y value?
Is it possible to remove the Date and degrees?
See the image
imageCompact Tool Valuies Window.png / V - Attached On 2015-08-08 17:31:14 UTC - Size: 2.33 KB - 397 views
[2015-08-10 17:07:14]
If you are only interested in the Y value, then you will want to use the Chart Values tool and have it active when other Tools are active. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValues
This particular setting is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings
You will then see the Y value on the right side of the chart. The Compact Tool Values Window was not meant for only this purpose.
Date Time Of Last Edit: 2015-08-10 17:07:42
