Date/Time: Mon, 25 Nov 2024 06:46:14 +0000
Main window scroll bars
View Count: 2092
[2015-08-07 10:15:18]
davidbrooke - Posts: 55
Can the main window scroll bars be disabled? In the attached photo are two arrows pointing to: a bottom horizontal scroll bar and a vertical scroll bar on the right hand side. These scroll bars pop up sometimes and I'm not quite sure why which means I have to start moving / resizing the individual chart windows to get rid of the main window scroll bars. Please advise.
imagescrollbars.png / V - Attached On 2015-08-07 10:14:28 UTC - Size: 317.38 KB - 453 views
[2015-08-08 02:53:26]
The only thing that might help is this setting in Global Setting >> General Settings:
https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#EnableWorkspaceScrolling
[2015-08-10 02:57:04]
Global Setting >> General Settings >> General 2 >> Enable Workspace Scrolling
wasn't enabled. Any other ideas?
[2015-08-10 04:27:49]
In this case it means they cannot be removed and they are provided by the operating system you are using.
[2024-03-19 14:05:10]
wavepaver - Posts: 1
Can the opposite of this be a potential? My scroll bar does not appear when I 'Enable workspace scrolling" the scroll bar at the bottom does not appear. Using Windows 11 on a ASUS Vivobook
[2024-03-19 15:35:01]
After you enable "Workspace Scrolling" you need to restart Sierra Chart. Refer to the information here:
General Settings Window: Enable Workspace Scrolling (Global Settings >> General Settings >> GUI >> Scroll)
