Date/Time: Sun, 22 Dec 2024 05:51:27 +0000
is it possible to load to nasdaq composite index using sc
View Count: 1061
[2015-08-06 17:39:39] |
mario mario - Posts: 22 |
I am using sc through transactAT for the futures chart, is it possible to load to nasdaq composite index using sc THROUGH td ameritrade account. thanks |
[2015-08-06 17:57:24] |
We are not sure if the connection that Sierra Chart supports to TD Ameritrade provides the NASDAQ composite index. If you do have a direct Sierra Chart account, you can use the Sierra Chart Exchange Data Feed to get this index and other cash indexes. Refer to this section here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CashIndexes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
