Date/Time: Sun, 22 Dec 2024 05:04:39 +0000
Horizontal line that is a percent up/down from yesterday's close
View Count: 1159
[2015-08-06 03:36:12]
Rob_2560 - Posts: 20
Sierra chart
I'm looking for a way to plot a simple line on my chart that would be a horizontal line showing a 1% move up/down from yesterday's close. The market often reacts at these levels and I am trying to figure out how to plot them and just can't...
So if the ES closed yesterday at 2,100 a line would show up for today 1% up at 2,021 and a 1% down line would plot at 2,079.
Date Time Of Last Edit: 2015-08-06 03:37:58
[2015-08-06 14:33:49]
Sawtooth - Posts: 4141
Try this:
1) To get the previous day's close, add the Daily OHLC study. You can set the Draw Styles to Ignore of the subgraphs/lines you don't want to see.
2) Add the Study Subgraph Multiply study,
set the Chart Region to 1
set the 'Based On' to the Daily OHLC study,
set the 'Input Data' to Close,
set the 'Multiplier' to 1.01
set the Draw Style to Dash
3) Add the Study Subgraph Divide study,
set the 'Divider' to 1.01
[2015-08-06 17:45:32]
The Daily OHLC study needs to have Reference Days Back set to 1.
Using a division is not going to be a precise result.
You can use a combination of Study Subgraph Multiply and Study Subgraphs Difference instead.
Date Time Of Last Edit: 2015-08-07 04:06:17
[2015-08-07 02:06:39]
Thanks so much for this answer!
It worked. I like that Sierra Chart has solutions that don't need to be coded into a custom indicator.
