Date/Time: Tue, 11 Mar 2025 05:01:18 +0000
Trouble connecting
View Count: 1565
[2013-06-11 21:34:27]
McCracken - Posts: 1
I am trying to connect to Top Step Trader. When I set up the CTS T4 service and try to connect it says Unexpected Disconnect. I've verified the credentials. When I try to connect to the CTS T4 FIX server, it allows me to log in but then it says that Data Failed. I'm not sure what the issue is.
[2013-06-11 21:47:23]
CTS T4 FIX is still under development and cannot be used. You need to use the service named "CTS T4". After trying to connect, please post a copy of the Message Log, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
