Date/Time: Sun, 22 Dec 2024 05:09:41 +0000
CURSOR
View Count: 1134
[2015-08-05 16:46:49] |
tellerbe - Posts: 109 |
Is there a way to increase the font on the cursor? It is so small that I loose it on the page
[2015-08-05 17:16:31] |
We are not understanding this. Can you provide a screenshot showing us the cursor you are referring to. Here are the instructions to attach a file: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For instructions to change the font sizes within Sierra Chart, refer to: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html#Fonts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-05 17:17:22
[2015-08-05 18:44:21] |
The cursor is the arrow that moves at the direction of the mouse.
[2015-08-06 17:48:00] |
This is controlled through the Windows Control Panel >> Mouse >> Pointers settings.
