Date/Time: Sun, 22 Dec 2024 05:49:42 +0000
independent scale
View Count: 975
[2015-08-04 23:52:50] |
User742717 Mike - Posts: 86 |
Hello, I've noticed that the independent scale on charts doesn't scale studies when not locked.. not sure if this is the intended result. IE: http://www.sierrachart.com/image.php?l=143873227857.png Edit, also the reset doesn't seem to work correctly in independent scale, it seems remembers the wrong 'reset' Cheers Mike. Date Time Of Last Edit: 2015-08-05 00:16:03
[2015-08-05 04:29:15] |
Are you setting the Independent scale on a study or the main price graph?
[2015-08-05 05:58:37] |
Via right clicking the price axis on the charts
[2015-08-05 06:05:08] |
That does not make sense to set the main price graph to an Independent scale. What is it you are trying to accomplish? We recommend referring to the Chart Scaling page here: http://www.sierrachart.com/index.php?page=doc/doc_Scaling.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
