Date/Time: Sun, 22 Dec 2024 04:51:57 +0000
Trading stats
View Count: 849
[2015-08-04 23:41:38] |
davidbrooke - Posts: 55 |
I'm looking for the info concerning trading statistics. Please see the attached photo. Please advise. Thanks |
TradeStats.PNG / V - Attached On 2015-08-04 23:41:13 UTC - Size: 52.52 KB - 320 views |
[2015-08-05 04:29:33] |
Search for Trade Statistics using the search box at the top right.
[2015-08-05 05:09:39] |
I searched for "Trade Statistics" using the search provided on sierrachart.com I found this: http://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#TradeDataStudies Which looks like I will be adding studies to a chart? Is this correct? If so....is there a layout similar to the photo I have attached? If I have really missed something....please point me in the right direction. Thanks |
TradeStats.PNG / V - Attached On 2015-08-05 05:09:36 UTC - Size: 52.52 KB - 305 views |
[2015-08-05 17:38:22] |
Trading statistics are documented on the Trade Activity Log page: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
