Date/Time: Sun, 22 Dec 2024 05:52:00 +0000
Soybean Daily Chart has large final candle for several days now
View Count: 861
[2015-08-04 14:31:43] |
Demi1201 - Posts: 68 |
Hello, I am attaching an image from a chart of Daily Soybean Mini Futures price. XK-201511-ECBOT-USD I cannot find in the data a corresponding high price. Also, each day it is the end candle only which is disproportionate: http://www.sierrachart.com/image.php?l=1438698508554.png |
[2015-08-04 18:43:03] |
This is not the correct symbol for that market. Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings After this open a chart for: YK-201511-ECBOT-USD-1000 This is the symbol that must be used. If you notice any incorrect data select Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
