Date/Time: Sun, 22 Dec 2024 05:04:25 +0000
How can I transfer my SC w custom studies from my laptop onto my new computer so I can use the c
View Count: 882
[2015-08-04 14:05:48] |
johnbougearel - Posts: 26 |
I would like to be able to use on my new computer the SC charts with my custom studies that are on my laptop. Is there a way to do this so my custom studies are available to me on my new computer?
[2015-08-04 16:15:55] |
Sierra Chart - Max - Posts: 5756 |
Please refer to help topic 15 here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support |
[2015-08-04 17:35:39] |
Basically you need to copy the DLL (DLL file extension) and Study Collection (StdyCollct file extension) files from the Data Files Folder in the copy of Sierra Chart where they are located, to the Data Files Folder of the other copy of Sierra Chart where you want them. For more details refer to help topic 15: http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-04 17:38:01
