Date/Time: Sun, 22 Dec 2024 05:21:05 +0000
Status bar and Chart name
View Count: 1012
[2015-08-04 13:54:35] |
ertrader - Posts: 681 |
Hi Support, 1) Is it possible to modify what shows on the status bar? If not, can the capability be added? For instance, show Open, High, Low, Close wherever the cursor is. 2) Is there any way to remove or modify the bar right below the status bar? It seems quite a bit of screen space just for a title. I have reviewed the following but it does not say. http://www.sierrachart.com/index.php?page=doc/doc_StatusBar.html Date Time Of Last Edit: 2015-08-04 13:55:55
Header2.jpg / V - Attached On 2015-08-04 13:53:09 UTC - Size: 49.38 KB - 383 views |
[2015-08-04 18:21:22] |
1. No and this will not be added. You can move it to the right side of the ToolBar through: Global Settings >> Customize Toolbars. There is a different way this information can be viewed: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData 2. Yes. This appears to be a Chartbook tab. This can be removed through Global Settings >> General Settings >> Tabs: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-04 18:21:55
[2015-08-04 19:09:25] |
Thanks...that helps getting the chartbook tab title off. For 1) adding the compact tool values window in the same place kind of does the job...just little cumbersome for me. Not a big deal. FWIW...For efficiency, I was trying to get cursor values for OHLC into a toolbar so I did not need the compact tool values window and could take advantage of free space better at the top. Date Time Of Last Edit: 2015-08-04 19:10:30
Header3.jpg / V - Attached On 2015-08-04 19:10:24 UTC - Size: 41.88 KB - 342 views |
