Date/Time: Tue, 06 Oct 2026 19:36:18 +0000
Log popping on every start - chart update interval
View Count: 1208
| [2015-08-04 09:57:43] |
| User11942 - Posts: 298 |
Hello SC team, after updating to 1280, every time I start SC I get the log popping with exactly the same message. Please see quote below Software version: 1280 | 2015-08-04 05:49:15
What's wrong with that? Thanks.
Uses Old Spreadsheets | 2015-08-04 05:49:15 Usage end date: 2015-08-20 | 2015-08-04 05:49:15 Enabled for: Advanced Features. | 2015-08-04 05:49:15 Enabled for: Advanced Features 2. | 2015-08-04 05:49:15 Enabled for: Sierra Chart Historical Data Service. | 2015-08-04 05:49:15 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-08-04 05:49:15 Current selected Data/Trading service: Rithmic Trading | 2015-08-04 05:49:15 Chart update interval: 500 | 2015-08-04 05:49:15 * Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-08-04 05:49:15 2015-08-04 05:49:15 Local computer clock time | 2015-08-04 05:49:15 2015-08-04 09:49:15 GMT time | 2015-08-04 05:49:15 2015-08-04 05:49:15 Time zone adjusted time | 2015-08-04 05:49:15 Time difference to server time: 0 seconds. | 2015-08-04 05:49:15 |
| [2015-08-04 10:09:24] |
This will be solved in the next release.
