Date/Time: Sun, 22 Dec 2024 05:55:03 +0000
Detach Chart Window & Control Bar Buttons - Issue
View Count: 1087
[2015-08-04 09:29:52]
Marek F - Posts: 244
There is one chart in the main Sierra Chart program window ("main chart") and one detached chart.
Scenario 1:
1) Main chart has enable the Chart Trade Mode (only this one). A button CTMO is pushed in.
2) Click on main chart.
3) Next, click on detached chart. Chart Trade Mode is off, but the button CTMO is still pushed in !
Enable / disable the Chart Trade Mode of the detached chart is working fine, but the button CTMO is always pushed in.
Scenario 2:
1) Main chart and detached chart have disable the Chart Trade Mode. A button CTMO is pushed off.
3) Next, click on detached chart. Chart Trade Mode is off. The button CTMO is pushed off.
4) Enable the Chart Trade Mode of the detached chart. The button CTMO is still pushed off !
Enable / disable the Chart Trade Mode of the detached chart is working fine, but the button CTMO is always pushed off.
There are also the same issues with the Attach Trade Window To Chart Window (ATW) and the Trading Keyboard Shortcuts Enabled (TKS) buttons.
Version 1280
Marek
[2015-08-04 09:46:00]
This all sounds normal.
If you are referring to the buttons on the Control Bar attached to the main Sierra Chart window, then what you describe is totally correct.
The Control Bar on the main Sierra Chart window will never show the state of a detached chart window.
[2015-08-04 14:36:42]
Thanks for clarification. I thought this is abnormal behavior.
