Date/Time: Sun, 22 Dec 2024 05:54:59 +0000
Replay Mode show 1 level of bid size and ask size
View Count: 904
[2015-08-04 05:49:43] |
rex2nd - Posts: 12 |
Can Replay mode show first current bid size and ask size? thanks Rex |
[2015-08-04 05:55:52] |
This is not supported within Sierra Chart.
[2015-08-04 07:25:11] |
will it be in the future release? thanks rex |
