Date/Time: Fri, 22 Nov 2024 23:56:07 +0000
Chart Drawings
View Count: 1423
[2013-06-11 15:33:47] |
RadioDC - Posts: 29 |
I know you can draw a trend line on one chart and have it appear simultaneously on another chart by linking them together. Is it possible to link drawings on a price chart (a trend line for example)with a study located below within the same chart book. Thank you DC |
[2013-06-11 18:03:07] |
No, this is not supported.
