Date/Time: Sun, 22 Dec 2024 05:52:09 +0000
Clear Trade Orders and Data
View Count: 994
[2015-08-03 21:28:37] |
JayShea - Posts: 92 |
Hello I see how to "clear trade orders and data" in Sim mode but have been unable to find how to clear from the screen trades created by live trading. Please point me in the right direction so I will learn for good. Thanks JD |
[2015-08-03 21:37:49] |
Solved it. Cheers
[2015-08-04 04:46:40] |
You can only clear the Trade Activity Data which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ClearingtheLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
