Date/Time: Sun, 22 Dec 2024 05:07:37 +0000
Enable snap for Horizontal line
View Count: 1300
[2015-08-03 20:33:22]
davidbrooke - Posts: 55
I'm using a horizontal line on a chart and would like to enable snap so that i can place the line on the current units of the symbols instead of somewhere in between the units. Please advise.
[2015-08-04 04:54:19]
This should already be the case. This is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ToolValuesAdjustToNearestTick
[2015-08-04 09:17:05]
Thanks!
The following wasn't enabled:
Chart>Chart Settings>Advanced Settings>Adjust Tool Values to Tick Size
Currently it is enabled and autosnap works as expected.
