Date/Time: Sun, 22 Dec 2024 05:00:45 +0000
add symbol alert
View Count: 1059
[2015-08-03 19:52:42] |
davidbrooke - Posts: 55 |
I set a chart>add symbol alert and it keeps going off. How can I delete it? Thanks |
[2015-08-03 22:35:03] |
User869386 - Posts: 3 |
changing it to No Alert works for me http://screencast.com/t/da0Ob54fBm8
[2015-08-04 05:10:08] |
This is fully documented on this page here: https://www.sierrachart.com/index.php?page=doc/doc_AlertsManager.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
