Date/Time: Fri, 02 Oct 2026 18:48:20 +0000
BID and ASK in chart DOM columns
View Count: 1514
| [2015-08-03 18:03:59] |
| User144295 - Posts: 76 |
Hi Sierra Chart, I would like to ask if I need to do any special setup to see more BID and ASK numbers in chart DOM columns. At this moment I can see only one tick below and one tick above the current price. I am using Infinity broker but using SC real time data. Thank you very much for your advice. |
| [2015-08-03 18:37:15] |
You should be seeing more market depth data than that. When you select Chart >> Open Market Depth Window, how many levels of market depth do you see?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-03 18:37:31
| [2015-08-03 18:40:36] |
We now realize what the problem is. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AddingCMEMarketDepth Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-08-20 01:20:26] |
Hi Sierra chart support, I would like to clarify pricing. By following your advise on the link above I would be basically charged 15.75 instead of 3.25? Is this assumption correct? I would be deactivating this: Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts: Price 3.25 USD/month. Can only be used by Sierra Chart users with a trading account with one of the supported futures Trading Services. And I would be activating this: Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts: Price 15.75 USD/month. Can only be used by Sierra Chart users with a trading account with one of the supported futures Trading Services. I hope I understand correctly. Thank you |
| [2015-08-20 04:10:14] |
By following your advise on the link above I would be basically charged 15.75 instead of 3.25? Your understanding is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
