Date/Time: Sat, 23 Nov 2024 00:29:43 +0000
Disconnect
View Count: 1463
[2013-06-11 15:24:41] |
infpz - Posts: 826 |
Any idea what might cause this? There was no problem logging in and seeing data earlier today. Also, the trading platform is working normally. TransAct Trade server connection lost. Reason: Connection Was Closed | 2013-06-11 09:53:40 Connection to the service has been lost or not completed. | 2013-06-11 09:53:40 TransAct Service: Disconnected. | 2013-06-11 09:53:40 SC Index Data: Lost the connection to the server. | 2013-06-11 09:53:41 SC Index Data: Disconnected from the market data server. | 2013-06-11 09:53:41 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-11 09:53:41 |
[2013-06-11 18:00:48] |
Must be some temporary connectivity problem. We cannot say what the cause is exactly.
