Date/Time: Sun, 22 Dec 2024 04:56:54 +0000
last price vs yesterday's close chart
View Count: 1546
[2015-08-03 07:41:45] |
davidbrooke - Posts: 55 |
I was able to create, in ninjatrader, a chart that graphically showed the difference of the current price to the previous days session close. See attached photo sections 1 and 2. For example in section 1: ES current price - 2100.25 NT automatically got the current last price but I manually entered the second value (which was the previous days session close). The result of the difference was plotted on a chart. Is there something similar in SC that exists or will I need to create a study? Thanks |
es-nq_difference.PNG / V - Attached On 2015-08-03 07:34:07 UTC - Size: 29.56 KB - 381 views |
[2015-08-04 05:09:05] |
This can be done by using the following studies: Daily OHLC (This can be set to reference the prior day) Study Subgraphs Difference (This can be set to calculate the difference between the prior day close and the last trade price at each bar). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-04 05:09:34
[2015-08-04 22:24:06] |
Thanks that worked out great. I also created another user study with study subgraph multiply.
