Date/Time: Sun, 22 Dec 2024 05:04:19 +0000
How to make the DOM window apart of the chartbook?
View Count: 1662
[2015-08-03 06:14:45]
davidbrooke - Posts: 55
Is there a way to make the DOM window apart of the chartbook? Currently when I create a DOM via File>Find symbol>Open trading DOM, I get a separate window on the task bar from the original SC's window.
[2015-08-03 06:51:24]
Not totally sure what you are looking for. Maybe you want it to be always visible even when switching to another Chartbook?
[2015-08-03 07:23:35]
The DOM is a separate window from the chartbook. It isn't apart of the chartbook like the other charts are....there are two windows in my task bar....one for the chartbook and one for the DOM.
Can the DOM "be apart of" a chartbook "like the other charts"? I have attached a photo showing the DOM window on top of the regular SC's window with the chartbook.
imagedom.png / V - Attached On 2015-08-03 07:23:10 UTC - Size: 277.14 KB - 457 views
[2015-08-03 09:20:15]
Go to the Trade DOM and select Window >> Detach/Attach Window.
[2015-08-03 13:19:03]
Thanks .....that worked.
