Date/Time: Mon, 21 Sep 2026 07:55:38 +0000
Signal Only Once Per Bar
View Count: 1617
| [2015-08-03 00:02:35] |
| Sawtooth - Posts: 4354 |
In the Spreadsheet System for Trading study settings, does 'Signal Only Once Per Bar' apply individually to Buy Entry and Sell Entry? IOW, with this set to Yes, can there be one Buy Entry and one Sell Entry in the same bar?
| [2015-08-03 00:29:15] |
We will check on this and update the documentation to make this completely clear. The answer should be: Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-08-04 05:27:18] |
The answer is Yes. The particular message which logs this condition when a signal is ignored has now been clarified: " Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar." Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
