Date/Time: Sun, 22 Dec 2024 05:01:25 +0000
Cumulative delta bars on daily chart
View Count: 1346
[2015-08-02 22:34:32]
davidbrooke - Posts: 55
Does cumulative delta bars work on a daily chart? If some please explain. If not, is there another alternative?
[2015-08-03 04:54:01]
No, it does not work on Historical Daily chart bars.
However, you can set the bars in an Intraday chart to have a timeframe of 1 day per bar through Chart >> Chart Settings. This is documented here:
http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#CreatingDailyBarsCustomSessionTimes
Date Time Of Last Edit: 2015-08-03 04:54:25
[2015-08-03 05:56:01]
Thanks for the reply!
After reviewing the documentation:
"Set the list box for the Chart Data Type to Intraday Chart Only (above the Intraday Chart Bar Period frame)."
I tested both:
Intraday Chart
Intraday Chart Only
I couldn't see a difference in the result. Is there a difference?
[2015-08-03 06:49:57]
There is not an obvious difference. Only if you were to press for example the Daily (Dly) bar period button on the Control Bar, will the chart remain as an Intraday chart.
Date Time Of Last Edit: 2015-08-03 06:50:24
