Date/Time: Sun, 22 Dec 2024 04:59:14 +0000
Control Bar - Display issues
View Count: 1010
[2015-08-02 19:38:29]
Marek F - Posts: 244
If the Control Bar is set horizontally and float, then there are 2 issues of display:
1) Is not visible Separators.
2) The Buttons have different width.
See pic. Can you fix it?
Marek
imageControl Bar.png / V - Attached On 2015-08-02 19:35:37 UTC - Size: 17.68 KB - 327 views
[2015-08-02 21:17:44]
We have to see about this. There is a reason why it is the way it is.
