Date/Time: Mon, 21 Sep 2026 03:59:37 +0000
Volume counter
View Count: 1410
| [2015-08-01 14:22:28] |
| pismo10 - Posts: 171 |
Does Sierra have a tool that counts volume from point to point on a chart? Like say an arrow or line that could be drawn from one point in time to another then a number posts somewhere indicating how much volume has traded between the two points. Could one be developed somehow by me or someone? Does it sound complicated to do so? Thanks SteveL |
| [2015-08-01 22:07:17] |
Yes. This is the Chart Calculator tool. It is documented here: Chart Drawing Tools: Chart Calculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
