Date/Time: Sun, 22 Dec 2024 03:25:04 +0000
[User Discussion] - ACSIL - s_SCPositionData - structure - request for additional fields
View Count: 927
[2015-08-01 05:20:16] |
ejtrader - Posts: 688 |
SC Team - Wanted to find out the true AveragePrice of the current position considering multiple scale-in/scale-outs. Looking at the s_SCPositionData - structure - none of the fields seems to account for closed PL due to multiple scale-in/scale-out cases that would have been part of the trade since most recent flat/opposite position. Would you please see if it is possible to add the field: cumulativePLsincelastFlat or CurrentPositionClosedPL This would be very similar to already existing field CumulativeProfitLoss with an additional requirement to reset to zero under any of the following conditions. - when the most recent fill makes the position flat - when the most recent fill makes the position to go from long to short (was not flat during transition phase) - when the most recent fill makes the position to go from short to long (was not flat during transition phase) Thanks Date Time Of Last Edit: 2015-08-01 17:05:23
[2015-08-02 01:10:32] |
I certainly didn't have much hopes that you would add this field. However instead of marking this as an user discussion, would have appreciated if you have provided a reason - even a simple sentence - "due to complexity we won't be able to add this field". I would find my way around this. Date Time Of Last Edit: 2015-08-02 01:10:58
