Date/Time: Sun, 22 Dec 2024 05:04:25 +0000
User Questions
View Count: 1210
[2015-08-01 01:38:13] |
Sierra Chart - Max - Posts: 5756 |
I have one client that is trying to introduce an automatism in a chart for replying later on all the charts. This is what he does: from Studies to graph he goes in the Setting folder and then in the tab Alert. Here he write his string CROSSFROMBELOW(ID1.SG1.ID1.SG2) he has another string but before this instruction he should write =or * or something other and he does not what apply. He gets the error ARGS! Could you please help him out? Thank you Sierra Chart Support |
[2015-08-01 03:04:43] |
The proper formula is: CROSSFROMBELOW(ID1.SG1, ID1.SG2) The formula does not have to have an = in front of it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-04 01:49:10] |
This is the formula they need to use: CROSSFROMBELOW(ID1.SG1, ID1.SG2) Use this formula. Notice the comma between the two Study and Subgraph references. It needs to be a comma character. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
